Sapphire Radeon HD 7790 1GB - Overclocking
Although Sapphire has already applied its own overclocks to the Radeon HD 7790 1GB GPU, we naturally wanted to see just how much it could really do. We used AMD's own OverDrive software for the task, and eventually settled on a core frequency of 1,200Mhz. This is the maximum that the software permits, and represents an overclock of a whopping 20 percent from stock speeds. Sadly, we couldn't push the memory to any meaningful frequency above Sapphire's 1.6GHz (6.4GHz effective) without the card becoming unstable. This is still an overclock of just under 7 percent from stock settings, however. With the overclock applied, we re-ran the Battlefield 3 and Crysis 3 1080p tests as well as the Unigine benchmark.
AMD Radeon HD 7850 2GB
Spphire Radeon HD 7790 1GB (OC)
AMD Radeon HD 7790 1GB
Nvidia GeForce GTX 650 Ti 1GB
AMD Radeon HD 7770 1GB
Frames Per Second
Frames Per Second
Sapphire Radeon HD 7790 1GB (OC)
200
300
400
500
600
700
Score
Read our
performance analysis on the next page.
